jestersv
lights go out at 17 mph not distance traveled and it is probably the switch in the door...common problem have you figured out which door is causing light? gem will probably keep lights on for all doors....
My girlfriend's 02 Explorer is doing this...very annoying. You can shut them off with the dimmer....problem is if you don't shut them off when you park it the lights stay on. I tried spraying the latches/hinges with copious amounts of WD-40 last night....no fix.
Anybody ever actually replaced the switch? Any idea how much? (Or how)
A good penetrating fluid works much better for this than WD-40. Release-all is one that comes to mind.
Sometimes when it says my door is ajar, I just hit the window switches and it goes out.
The GEM module (99-01) or the VSM (02-03) control the delay for the radio, windows, etc... for when the ignition is turned off. They also handle the door locks and take the reading from the door sensors to know if the doors are open or not.
If your problem is only the truck thinking the door is open, the best bet is to try to spray the sensor in the door. If there are symptoms in multiple systems, or if one system being turned on fixes the other, it's probably the GEM or VSM.
The GEM is behind the fuse panel and is very susceptible to water from a leaking windshield. The VSM is behind the backseat and is susceptible to water from a leaking back glass.
