6.0L Stroker
Very true Matt. Those changes should make a big difference in the reliability of that turbo as well.
I just went from the SPE tunes and now updated to .31 h&s tunes. I took it for a few miles down the road and I liked it. Nice and smooth shifts. If SPE tunes had the adjustment where it slowly spools the turbo instead of instantly spiking to 30lbs then dropping back off.
Umm all I did was update to h&s tunes. And when I put sd card back in select install h&s tuning. I never did anything with the custom MCC tunes
Nope, not right... Black Maxx should be showing .29 and Mini Maxx should show .31 after the update. Some people have had to update the entire SD card in order for the update to work. Give that a try.
Also if you think about it these trucks under regen go almost 1500 degrees at times so what's a couple more hundred?!?!
