New recruit 04 psd
WILD_PHIL
East TX
Welcome to the site.
E99 F350/zf6/guages/arp/comp/stellite/ billet wheel/ bellowed... Need more fuel and more air.
WILD_PHIL
East TX
We're gonna need some more info buddy. How's it run when driving? Any smoke?
joelpsd0460
Thanks. It's super intermittent. It's been fine for a week then acting up again yesterday. Rough idle on coast. Then goes away on acceleration. No smoke of any sort. Sometimes when idling in drive it starts loping. It will drop down to 500 rpm then up to 1200 and all over the map. Trucks got 60k on it and 8 months ago did the icp, ipr, stand pipes, injector harness glow plug harness air dog lift pump air sep driven diesel regulated return and arp's. What do you guys think? Appreciate the help.
joelpsd0460
Yeah no codes yet, my scanner won't read oil pressure so il have to wait till its worse then maybe plug into a shops scanner, any idea how to test my icp? thanks
pdumont01
CT
If your gauge isn't reading on the dash you most likely have a high pressure oil leak. U have a tuner that may read the pressure, if the cranking ICP is under 500psi the injectors won't be fired.
swinky
Eastern, Nc
What gauge are you talking about? No gauges on the dash can tell you anything about hpo.
unplug the icp sensor and see if it changes
I'm with stupid ^ as per the usual.
Sent from my HTC One M9 using Tapatalk
pdumont01
CT
If there is a large HP oil leak the low pressure gauge in dash will not show pressure. I have had hundreds like that. Next time someone has a stc fitting or a rail block off plug causing a no-start look at the dummy gauge on dash, guarantee it won't show pressure.
pdumont01
CT
Look at gauge "while cranking" during a no start condition.
pdumont01
CT
Read what his problems are man.... Nothing about a no Start.
You asked how the oil pressure gauge can show a high oil pressure leak, that was not meant to tell him what was wrong with the truck. I don't believe I told him that's what his problem was.
yore posts are starting to get annoying. "know-it-alls" dont last too long around here...
pdumont01
CT
I have an idea stop cluttering up threads with this B.S. you seem like the biggest know it all on this site. I'm not going anywhere bud so get used to me posting.
swinky
Eastern, Nc
Keep in mind this is the same guy that compared a focus transmission to a 5r.
Pretty useless guy here ehh?
the re-instatement of Confederate Diesel haha
pdumont01
CT
Ur an idiot re read the posts no time did I ever compare the 2 transmissions and say the 4f27e is like a torqshift. Seems like you have problems reading and interpreting words, probably the reason you need to have other people build your transmissions so they don't fry.
