joelpsd0460
- Joined
- Aug 9, 2015
- Messages
- 3
- Reaction score
- 0
Lookin for advise on an 04 6litre running rough on coast and idle. :ford:
What gauge are you talking about? No gauges on the dash can tell you anything about hpo.If your gauge isn't reading on the dash you most likely have a high pressure oil leak. U have a tuner that may read the pressure, if the cranking ICP is under 500psi the injectors won't be fired.
Sent from my Nexus 6 using Tapatalk
I'm with stupid ^ as per the usual.unplug the icp sensor and see if it changes
If there is a large HP oil leak the low pressure gauge in dash will not show pressure. I have had hundreds like that. Next time someone has a stc fitting or a rail block off plug causing a no-start look at the dummy gauge on dash, guarantee it won't show pressure.What gauge are you talking about? No gauges on the dash can tell you anything about hpo.
Sent from my HTC One M9 using Tapatalk
Read what his problems are man.... Nothing about a no Start.Look at gauge "while cranking" during a no start condition.
You asked how the oil pressure gauge can show a high oil pressure leak, that was not meant to tell him what was wrong with the truck. I don't believe I told him that's what his problem was.Read what his problems are man.... Nothing about a no Start.
I have an idea stop cluttering up threads with this B.S. you seem like the biggest know it all on this site. I'm not going anywhere bud so get used to me posting.yore posts are starting to get annoying. "know-it-alls" dont last too long around here...
Keep in mind this is the same guy that compared a focus transmission to a 5r.yore posts are starting to get annoying. "know-it-alls" dont last too long around here...
Pretty useless guy here ehh?
Ur an idiot re read the posts no time did I ever compare the 2 transmissions and say the 4f27e is like a torqshift. Seems like you have problems reading and interpreting words, probably the reason you need to have other people build your transmissions so they don't fry.Keep in mind this is the same guy that compared a focus transmission to a 5r.
