NEW* Super Bright CREE LED Reverse Bulbs
15
Why would you hack your wiring to install resistors that create heat (sometimes to unsafe levels) when you can simply turn the rapid-flash off with FORScan for free, or IDS at the dealer?
C2tuck
North Texas
Didn’t know you could sootie...didn’t know that was an option.
oli6578
Orange, TX
More info on this please. I seen a video of somebody doing this to a 2017. Didn’t know this was a option on a 2016.
oli6578
Orange, TX
Here is what I found in a ford bulletin to fix hyperflash with IDS. I will do this when I upgrade to LED Switchbacks.
C2tuck
North Texas
I know it’s probably been answered somewhere but will forscan software work on apples? That’s all I have.
C2tuck
North Texas
Ordered me a usb-obd2 cord and should be home when I get there. Hopefully this will work!
C2tuck
North Texas
Ok so I got it fixed with forscan...what do I need to do to ship these relays back to you?
retrosolutions
Super Bright CREE LED reverse bulbs
Fits 92-09 Ford Trucks!
*Note: may exclude some models with different fixtures/sockets (other fitments available)
only $36.99 /pr!!!
NEW VERSION
BRIGHTER and WIDER TOTAL OUTPUT than previous versions
UNLIMITED RUN TIME, TEMPERATURE COMPENSATED
To place an immediate order, CLICK HERE
- 6x CREE XB-D series technology LEDs (R5 binned!)
- very wide and bright 360° distribution
- focusing lens and side firing LEDs for excellent coverage
- self compensating for running temperature
- Fits stock location, just pop it in
- Works in any 8-18v vehicle/socket
Currently $36.99 per pair!
Each bulb consists of a 6 LED array using CREE's latest generation X-Lamp series. These LEDs pack a very big punch in a very small package, with excellent luminous efficiency, and advancement in thermal transfer.
Each bulb totals more than 875 Lumen of directed light output at maximum output. That's more than twice the output of the stock bulb they replace.
Now only $36.99 /pr!!!
Some real customer example photos:
Just the CREE LED bulbs:
CREE in comparison to the Stock bulb on opposite sides:
No reproduction, re-posting, or copying of images, text, or other media allowed without contractual permission
Retro-Solutions, LLC 2018 All Rights Reserved
