06 BLACK DYNAMITE!!!
Looking into throwing some nitrous in the mix. What are some good options and what are the pros/cons of running nitrous. Most likely I'll be running a single stage so what size shot? Let me hear your thoughts.
Well the first CON is I just got a 180 dollar fine for illegal vehicle modification for having a nitrous bottle in my bed. Didnt even have the line hooked up. If I get caught with it again my truck gets impounded on the spot
I'm running a 68mm VGT. Would I have to run a wastegate?
What state are you in? Is that a state or federal law?
In Canada, nitrous runs around $10.00/pound.
.....cheaper to just get the right turbo, or turbos in the long run.
I'm pretty sure Stonepusher was spraying his barder 68 to upper 800hp without a wastegate and he had no problems. I think it was a dual stage.
Actually with the new sticks it trapped 126mph in the 1/4 and that was one stage, puts it a lil above 900hp. After world finals I may see what 2 stages will do with the bigger sticks :jawdrop: before the new sticks with the 225/100's it did 865hp on two stages and trapped 123mph.
