Duty cycle starts at 15‰ then shoots up to 65%. Icp goes up to about 156 psi and doesn't build any higher
Sent from my SCH-I535 using Tapatalk
One more thought, if you still have the fuel bowl and removed it to replace the hpop, did you pull your filter and cycle the key?
well youve definitely got an oil leak somewhere.
I took the hpop line off the head and it's more of a bubble out. I guess I was expecting more of a gush and make a big mess.
You probably just introduced even more air into your hpo system. Are you saying you pulled the line off and cranked the truck? If so, you should have a huge mess. Have you checked the engine oil level to make sure you have enough oil to even fire the injectors?
If a injector was stuck open would I get smoke?
why do i feel like that HPOP was good but is now bad. and if it was stuck open it should be pouring fuel down into the cylinder.
is this a new srp 1.1?
