Non Vgt question
Josh@DirtyDiesels
PA
Man thats wild. I could light my 475 on the line easy with my 2000 stall IIRC
I watched your video while I was having this issue and couldn't believe it!
DPC converter right?
PI converter. I mean I was told it was a 2000 stall. It has always felt somewhat loose. Still feels a lot tighter than the 2700 I had in there for a little bit.
04cr450
harford county, maryland
From what andy told me.. he thinks the pi 1800 and 2000 are the same no difference. . I dunno, all I can say is my setup and trans setup spools up the turbos effectively. I have been in a 2200 stall 6.0 and it felt way different than mine. A "loose" feeling when taking off if that makes sense
jban126_f350
Phoenix, MD
What injectors are you running? I only have 190/100 with a vgt 68mm lags like crazy most the time. Stock stall as far as I know. Think 190/100 stage 2 cam will spool a 64.5 alright for a daily? Again my motor has to come out again so I'm gonna do non vgt and converter. Possibly 2200 Marty told me to do a 2000 but you guys are saying there's not much of a difference on that? Who knows 2000 might be in it now?
04cr450
Marty will make things rite.. he has a nasty single cab to prove he knows his non vgt setups. Yes a 64.5 will spool those injectors fine even without the cam.. with the cam just a added benefit. What does Marty say?--listen to him. I thibk WE are all confusing you, just listen to Marty about the setup and you shouldn't be disapointed. He has helped me with my new motor/setup immensely.
04cr450
Crazy. Wonder what the hell happened to mine lmao
Haha who the heck knows.. seems like the new converters are hit or miss stall wise. Even with my new build I am sticking with 1800, I might be kicking myself but the Compounds will make it more forgiving from what I've been told. Keeping it simple.
Mdub707
Mohawk NY
There are so many variables being thrown around right now I don't think we can keep any of this straight.
Axle ratio and tire size are also going to play a huge role (in normal driving situations).
Let's not forget that stall speed changes based on power output too. A 2000 stall converter on a 400hp truck is not a 2000 stall converter on a 700hp truck.
Six_Sloww
Southeast MI
True, but a 700hp truck makes 100hp when it can't make any boost lol.
I'm sticking by my 2200 stall suggestion for a 64.5/73/.91 at least if it's a little loose you can get it lit and get out of the hole.
jban126_f350
Phoenix, MD
Okay so I plan on lowering the truck back to stock height and doing a rear lift spring block ****** in the spring. Called Andy warren he is telling me to do a 2000 stall and Marty is telling me to run a s363 sxe with the 190/100
jban126_f350
Phoenix, MD
Hey what intake is made without the ccv hole in it? No limits? Thinking about doing mpd ccv reroute that they come out with
