Non-VGT vs. VGT (video heavy)
Dzchey21
wyoming
looks like it doesnt even make boost till 3000 rpm??? Or did i see that wrong? Def making ***ing power tho holy ***
Dzchey21
wyoming
Would have been better if it shifted to 1st
Sent from my Droid Charge
Do a similar pull to mine 45 MPH in direct gear and just roll into it don't let it downshift. Whole purpose of the thread is to.show spool up
Dzchey21
wyoming
So you want me to keep it in od?
No direct gear. Should be around 1500 rpm at 45 MPH
I like driect gear pulls because its easier on the trans you don't have to go much above the speed limit to.do it and the converter is locked the whole time. And as long as it doesn't down shift it seams to be the safest as far as traction goes
Dzchey21
wyoming
ok so i cleaned up about 130 posts out of this thread, i want to keep this one on topic because there is sooo much good info in here, and plenty of vids for people to see, so please keep it on topic. Post videos if you got them, and if you have questions about peoples set ups, a little search will go along way as most of these trucks have build threads on here already with all the details.
Thanks
on that note here is my vids
45mph roll to show smoke
http://youtu.be/egMk4DaGWps
20-70 mph light accelerating to show boost
http://youtu.be/S1x4HQvUExQ
45-100 roll with no down shift to show spool up under hard acceleration
http://youtu.be/J6tsScPJgn8
video from 60-80 in overdrive to show drivability in overdrive and on the highway
http://youtu.be/6aDhB39JZQU
01PSD
Smithfield, NC
I remember it had max powers, wasn't sure if they had changed or not, looks freakin BA! Got a little squirrely huh? LOL
