Official DPC 2013 Updates
BDP Sales
Murfreesboro, TN
Beech 6.4L Powerstroke-687.9hp 1397.7ftlb
Rizzi Duramax-919.8hp 1465.4ftlb
(Out)-CADP
Cato Dodge Cummins-563.2hp 1086.7ftlb Blew rear freeze plug
Woosley Dodge Cummins-1255hp 2063ft/lbs
Hillison Dodge Cummins-1009.8/1885.7
Heafner 7.3L Powerstroke-642.6hp/1350.9ftlbs
Lewis Duramax-814hp/1423.8ftlbs
Doyle 6.7L Powerstroke-744.2hp/1411.9ftlbs
Clausen 6.4L Powerstroke (Reigning Champ)-1086hp/1926 ftlbs
01PSD
Smithfield, NC
The setup on Woosley's dodge must be pretty crazy to be 200 HP higher than Erik, then again I'm not sure how much spray either used.
bluedge8
Champlin MN
Beech 6.4L Powerstroke-687.9hp 1397.7ftlb=2085.6
Rizzi Duramax-919.8hp 1465.4ftlb=2385.2
(Out)-CADP
Cato Dodge Cummins-563.2hp 1086.7ftlb Blew rear freeze plug=1649.9
Woosley Dodge Cummins-1255hp 2063ft/lbs=3318.00
Hillison Dodge Cummins-1009.8/1885.7=2895.5
Heafner 7.3L Powerstroke-642.6hp/1350.9ftlbs=1993.5
Lewis Duramax-814hp/1423.8ftlbs=2237.8
Doyle 6.7L Powerstroke-744.2hp/1411.9ftlbs=2156.1
Clausen 6.4L Powerstroke (Reigning Champ)-1086hp/1926 ftlbs=3012
figured I would score them the way they are scored in the event, of course I think these numbers are uncorrected and they use corrected numbers, but should still be the same rank.
treed by BDP Sales!
Powersmoker
Chesapeake, Va
We were having nitrous issues on out big NX kit, narrowed it down to a bad controller. The solenoids would come on, then immediately shut off. So basically it was a 45 psi dyno pull with a .052 jet. (Separate spool up solenoid) Sucks, ohh well.
Sent from my iPhone 4S using Tapatalk 7
01PSD
Smithfield, NC
Fixable?
