Oil filter relocation...
Matt
Minnesota
Does anyone make a plate for-12 lines? I have a plate from Trusted that uses-10 and then I got an adapter fitting to go up to-12. It'd be nice to have it all -12 though.
Skinny
British Columbia, Canada
Is -12 5/8s or just a tad bigger or smaller then that?
I have all the info on my work computer aswell I'm going to call Donaldson to verify the info
Skinny
Waiting for Donaldson to call me back the info i was told early is not correct..I called Amsoil the EaO80 only flow 15gpm being told they are the same filter so waiting to see what Donaldson says might go back to the drawing board.
Donaldson Filter # ELF 7349
Pizza pig
MD
I alteady said what filter to use, the 7.3 filter, doug at Gogo has the plates that use -12
Matt
Minnesota
Moroso makes a filter mount for the 7.3 filter with -12 lines. Can't remember the part number though
Pizza pig
MD
yup, i have it written down somewhere, I will try and find it. This is the piece that im using, theyre expensive though.
Snake
Flo Rida
Skinny, any chance you can get a full spec sheet from Donaldson? Whoever you spoke with maybe? A filter with an absolute rating of 15 microns that flows 20 gpm is a unicorn.
