Oil filter self tightening?
01pwrstkr
Polk County NC
I allways gave a half a turn with the wrench otherwise the filter would leak and never had a problem getting them back off.. The outer shell of a Motorcraft 1995 is stronger than some of the aftermarket ones.. I allways poked a hole in the bottom of the filter before removing it..
^^^This^^^ plus oil on the seal and have never had any problems.
Az00r6
This happened to me once I alway oil my oring hand tighten and my threads alway seem fine and last time I changed it I could not get the damn thing off I ended up using one of the chain type oil wrenches pulled broke the chain off I was able to go one link tighter and was able to get it to budge then it spun right off like nothing. But the chain didn't slip on the filter you just want to get it as high up as possible so you don't crush it
bluedge8
Champlin MN
Was the handle of the wrench at the back of the filter pushing towards the frame ?
Brad.S.19
Maine
Yes I am turning it counter clockwise I have been double checking with a ratchet since the truck/filter style is new to me. The mech I used put oil on ring filled it first like any other rig it baffled him. He is thinking it swelled some and just wait a 1000-1500 miles then do another change I just do not want to repeat last time I learned my lesson on a few things.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
02BigD
Coastal NC
Lets put an end to this question..
Skip to 1:14
He's in the same state as you...can't be too far from you LOL why don't you run over and rip that thing off for the poor guy. Bet you could do it with just a mean look...
Brad.S.19
Maine
Make him take it off...
Take it back.
Let him do it.
You put the new one on so if this happens again you have nobody to blame but yourself.
Well guy he is I am asking if this is possible for the ***kin filter to self tighten. I did not put this one he did so he is taking care of it under his warranty.
littleredstroker
where the antelope play
I don't believe they would tighten from the recommended 3/4 turn past when it bottoms out, to where you have to replace the oil cooler end cause you cant get it off...
Brad.S.19
Maine
Honestly it is just as bad as last time some else can deal with it.
My neighbour can walk by it may fall off in horror and run.
Atsah
Maine
I am closer to Canada than most towns in Maine Dom..
02BigD
Coastal NC
I hear you. I'm was really reaching for this guy with that comment Mark. I'm certain he's very frustrated that his new pride and joy is having issues and I don't want to see that for him all joking aside.
