Parts for 600hp?
smokedout250
harrisburg oregon
so do you think the 150's are making you more laggy than if you had smaller nozzles?
I honestly do know yet... The previous owner Loboost had better success with this setup. He didn't have the spool issues I do... I'm gonna triple check everything and make sure I have no leaks on anything... I may have a bad ic allowing boost to leak but I doubt that is the case...
Josh@DirtyDiesels
PA
There is definitely an issue. I ran 150 nozzles with a 366 and it spooled like stock. I think I have some vids on my youtube
smokedout250
harrisburg oregon
In my lower gears it spools great. But up in the high gears it takes for ever... I am on 35s with stock gearing... As long as I'm 1800rpm and above it's spools instantly... Anything below that it's smokey and laggy... Egt are staying in check 1300* wot... I'm just wondering if my bigger tires are putting me under the turbo at cruising speeds... Once it's lit cleans up great little but of a haze and that's it...
Josh@DirtyDiesels
PA
just kick it out of overdrive if you are stuck in low rpm's and need to move out without smoking the road out. Have your tuner write you a tune that makes the tow haul button cancel overdrive. Best thing you can do with a biggish non vgt charger
smokedout250
harrisburg oregon
That's what I do, I talked with Matt and we are gonna do some hard work on the tuning once I get my trans done and get my nozzles swapped... And I will prolly drop a tire size this Summer...
william_ace
Interesting. Are you holding ICP? I'm also contemplating going with 205/75s with my BTS 68mm. In to see how you like the nozzles with a 205 body!
smokedout250
harrisburg oregon
I'm very interested to see how things change with the nozzle sizing and a better trans... As for icp I reall doubt I'm holding a decent icp.... I haven't been able to get and accurate reading due to a trans slipping and I'm not going to open it up on public roads lol
smokedout250
harrisburg oregon
I actually got this setup from a member here... We swapped... He wanted a towing friendly setup and I wanted more power. That's how I got 150s as for elevation 400ft above sea level
