Thanks V-Ref,
Unfortunately that may not work for me. The X, as well as some of the later model SD's "I think", have a heater loop cut off valve. It's vacuum actived when you move climate control to max A/c setting. (Bob Riley sells one as well to help get that super cold air.) If you had it spliced in line (series) be it feed or retro hose of the heater core you would loose all flow. At least that is how I see it. One way around it is a bypass loop. T into heater core feed hose as turbo inlet and heater core outlet (post cut off valve) for the turbo return.
Ideally I would think getting good the coolest source of coolant for inlet and then return would be ideal. But what if anything would be gained. So likely not worth me over thinking it.
