Powerstroke214's build thread
Powerstroke214
Baton Rouge, LA
A bad injector will most likely not throw a code unless it is absolutely awful. I had four injectors gone-the truck would hardly drive and it didn't set a code. You probably have already checked the basics but:
Fuel pressure, injector contribution balance, ficm main voltage. Then more in depth is pull the valve covers and check for high pressure oil leaks. Another trick is if the miss is at idle you can disconnect the icp pigtail and see if it changes. That will force it to a default setting. You may have a bad icp sensor.
Is the miss consistent? Only when it's cold? Only at idle? Sorry for being disjointed-im tired...
It's cool lol
To check everything you said, what all would I need? I could get the livewire up and running soon, but for contrib wouldn't I need a AE or something?
It's mostly at idle(that I noticed) and while I was backing into a parking spot, it started jumping a little, then later it had a shake while it was idling. I rev'd it to 12, 15 and 2k rpms and I didn't notice it.
It's doing it hot.
I'll try to check for HPO leaks this weekend and the ICP sensor.
Sent from the Bayou
weazel
Elkview WV
It's cool lol
It's doing it hot.
Sent from the Bayou
Tell you what, I'll give you $50, cash money, and take that thing off your hands. To save you the heartache
Sent from in a ditch up side down and on fire with the wheels still spinning
Powerstroke214
Baton Rouge, LA
For some reason or another…I'll pass. Hate to see this thing with no bed and a batman stack :poke:
Sent from the Bayou
weazel
Elkview WV
Sent from the Bayou
Hater, I have an 8" lift for it just sitting on a shelf, and the awful batman stacks are my ticket to SEMA, and not installed on the Ox (thank god) and I will be building the bed right after SEMA
It's cool lol
It's doing it hot.
Sent from the Bayou
you can check ficm main voltage with the livewire. i have always used IDS to test the injectors. most dealers will help you with some diagnostics for free depending on their workload.
fwiw i have always had injectors issues very soon after a head gasket job or intrusive repairs of any kind LOL i think its oout of spite!
Powerstroke214
Baton Rouge, LA
And now, there is a mysterious burning odor. Seems like it's coming from the engine area, more specifically the rear. Smells almost electrical(?) I guess. Couldn't see anything(it was after midnight) so I'll look again in the morning. Coolant level is unchanged and the smell isn't coming from the exhaust. Any ideas?
Sent from the Bayou
weazel
Elkview WV
Sent from the Bayou
Did it start after you put the loud pipe on? If it did, make sure you don't have anything touching it, wires, or what have you
Powerstroke214
Baton Rouge, LA
Didn't notice til last night, so yea. I'll check to see of the dp is rubbing.
Sent from the Bayou
weazel
Elkview WV
Yeah start there, check up by the turbo flange all the way back
bluedge8
Champlin MN
Sent from the Bayou
what weazel said,,,, another thing to check, check all fluids- specifically the x-case. I had a bronco II back in the day that lost a bearing and blew half the housing off---- it smelled just like electrical,,,,,
Powerstroke214
Baton Rouge, LA
I know Mike asked, before things went fubar, I didn't get too in depth. The mid pipe slipped out of the extension so I went in and retorqued everything. I THINK the smell was coming from the sound deadening, which was touching the DP. When I noticed it, I had been hooning on it pretty good and I figure the egts were higher and toasted the deadening. Also, there is something rattling, I don't know what it is, I think it's exhaust, but nothing under there can rattle that easily/quickly.
Sent from my iPhone using Tapatalk - now Free
weazel
Elkview WV
Sweet keep us posted, other than that, how is the truck treating you
O2ShootTheJ
my mbrp exhaust rattles and flies all over the place. I hear it banging into stuff all the time. Haven't had time to fix it..
weazel
Elkview WV
I use the weld on exhaust hangers with the polyurethane bushings. It does a pretty good job, considering I only have 1 on my entire exhaust system
Powerstroke214
Baton Rouge, LA
Let me know how you fix that. The mid pipe and down pipe slip around a lot, which I don't like. In all, the fitment is decent I guess, tail pipe and over axle piece are annoying to keep aligned when I try to tighten everything up.
O2ShootTheJ
Hoover said he just put everything in a bind and tightened it down so I guess that's what I'll do
