neverkickn
I would think that pump would prime dry. The oil coating is prolly just recommended to keep the parts from scoring.
What all did yall do when changing the pump?
Does the oil gauge come up?
Look in the HPO res...
Are you referring to it being installed backwards? I did that on mine at first, and thankfully caught it in time before installing the engine. With it installed incorrectly, it wouldn't allow the crank to turn over by hand. But I suppose the starter would turn it.
Incorrect installation can crack the front case, can't it?
Stock LPOP are marked/oriented, Mellings aren't.
Who caught thatoke:
X2...
In the event that it isn't working still I have removed the 1/8" plug at the back of the oil cooler and then used a port a power to pump oil into the system. Can't say for sure whether that is what made it work or not, but it did after I did that.
So what do I look for when installing the Melling pump???
I just got the truck to pop, exhaust smells like......exhaust but nothing promising. Im guessing until voltage is addressed this thing isnt going to run. New batteries and a good charge are my recommendation for now. That pump has to be swamped with oil. It doesnt need to prime when its.deluged with oil.
I just use assembly lube.
