powr2stroke
You're probably right Erik , just thinking out loud
Is the main tube bent or just the second bar running under the main tube. The procomp bars on my 2wd 7.3L have that exact same bend on the driver side, from some one being careless putting it on a rack. They still work fine. As long as your main tube isnt bent i would just run em till you can afford a nicer bar.
What did procomp have to say?
Looks like the required breakover on a hill you crested was a bit higher than the truss bar on your pro-comp bars and you shoved them into the ground and bent them.
Under power that part of the bar would likely be in tension, not compression, meaning the force would be doing exactly the opposite of what it would take to bend it like that.
You probably high-centered the truck over the bars and bent them. Whether or not you noticed when it happened doesn't really matter.
Sucks that Pro Comp won't help you out Cody, but I guess it's a good excuse to look in to some PMF or OUO bars.
I have identical mounts as those as I actually ran across some of the pro-comp mounts years back when I built my first set of links on my red truck.
The first links I built were probably identical in length to your current ones as I used the mounts as intended by pro-comp and simply made up a set of links myself.
The links I made, in the EXACT same mounts bent in EXACTLY the opposite direction from the ones in your pictures...
They deflected DOWN every single time. I even had someone else drive the truck and I watched them from the side, and they bent down tremendously as I did not gusset them, and the way pro-comp lays them out the links are pretty long.
So.... I can tell you from first hand experimentation... the links did not try to bend upward under load.
I personally never liked the idea of them being that long for geometrical reasons, and only did it because that was how they were "designed" by pro-comp. I re-positioned the front hangars where the links would form a much better angle with respect to the leafspring arc-path and made up some links from the same tube that were a fraction of the original length and they have been on the truck for years now.
The long links made the truck ride like sh*t anyway.
Charles, while you are spot on, you have to remember that these are on an 08+ truck that has very flat springs and have virtually no arc path. This could be the fact to why they bent upwards. There are a lot of variables that come into play, and one may be that they are just simply not strong enough.
I also wondered if this guys' links did in fact try to deflect downward and the truss bar went into tension, then if under shock loading like when bouncing under power if the tensile load in the truss bar wouldn't store enough energy to actually throw the whole link in the other direction when the tires lost traction momentarily, and then upon regaining traction actually deflect the links upward.
I never saw any hint of this wanting to happen on my truck, but... it wasn't gusseted, and as you say, my springs were much shorter, therefore steeper.
Mounting location. Either top, bottom or both with separate bars. Not in the middle.
If you month them top or bottom they are either in just tension or compression not both.
The only way I cans see the bars bending down is if you are on it, loose traction and the suspension unloads then regains traction with some suspension travel. The bar would go from compression, tension back to compression. This of course the bar is mounted to the bottom of the axle. With it in the middle would just multiply all of this.
My links are mounted on the exact same mounts as the OP. They have been that way for years. I have towed up to or over 30,000lbs gross as well as spun miles worth of rolling burnouts at 600+rwhp, plus just general shock loading of coming in and out of traction on dry pavement on a daily basis.
With the link in the centerline of the axle with the factory block under the leafspring the lower link is in pure compression and the leafspring has some of it's compressive load counteracted by a tensile load from the axle trying to rotate the top rearward under power. With the fixed link in the center of the axle handling the tendency of the axle to push forward, the remaining torque is traslated into that tensile load on the leaves.
Having the link end mounted in the center isn't a problem.
