Corb@CorbinShipping
Thanks BellyBoat.
Yeah I have heard it would only be released for the Mini and Black as well. Guess we will find out shortly. Heard MCC is in the beta test stage now. If every thing goes right should be released in a few weeks. Hopefully. I am going to pick up the Mini Maxx on Friday. Now I just need to find some thing that will give me data logging.
I have analog Glow Schit gauges. Should I put those in or just monitor the H&S?
The minimaxx is a good set of gauges. But it only displays 4 at a time. If you arent running anything really wild, I would say that the unit is enough. But, if you are pushing her hard, I would at least consider using the gauges.
If i had a separate pyro, boost, and EBP gauge, I would run them, as well as be able to monitor several other parameters as I saw fit to rotate and check them...
