question/tips/tricks/advice/how to thread
sagebel
East Chatham, NY
I ran a the Pro Dry S that didn't need oil. I hate dealing with oiling a filter. Now I need to take a look through my scrap pile for a piece of 4" exhaust tubing.
lincolnlocker
Central Michigan
It will have to be a 45° piece of 4 inch and you will have to adapt the mafs and protect the a/c fill tube.
live life full throttle
lincolnlocker
Central Michigan
I'll have to look but I think I have an extra stock intake lying around.
If you look close you will see that the stock tube is sorta coned. from the rubber boot to the air box it gets smaller in diameter. So 4 inch pipe would be best. Ill prolly do a mock up with regular ole 4inch exhaust pipe just to make sure its not going to throw codes... ill cut a piece of 3/8s bar stock and waller a hole in it to fit the maf sensor... if it works then ill either powder coat it or go stainless.
backwoodsboy
Merica
If I wasn't moving to CT and then on to WA after six months all within the next year I would be deleting the new truck.
As long as you stay out of the large metropolitan areas there are no smog inspections up here in WA. Clark, King, Snohomish, Spokane and Pierce county's are the only ones with any kind of smog
sagebel
East Chatham, NY
I'll be moving back to Kitsap county. If the timing works where I can leave truck registered in NM until I get to WA things may happen sooner. NM exempts everything 10,001 lbs GVWR and up.
lincolnlocker
Central Michigan
Holy crap, cleaning exhaust filter finally popped up on my screen... just bout 2k miles since I seen the last one pop up..
Have 17k on her now.
lincolnlocker
Central Michigan
Since the temps are getting down around 0.... and letting the truck warm up for 20min and driving for 15-20 min before hot air starts to blow out, was getting old fast..... I made my own grill cover, well, liner cuz its on the inside.. did it in the hotel last night...
Spindrift
Austin, TX
Yup....those pics of the blanket don't look like they're from inside the camper. I was wondering if you were still out of town.
Sent from my DROID RAZR HD using Tapatalk
lincolnlocker
Central Michigan
Blanket? But no. Fifth wheel has been winterized since october. I dont *** around trying to keep chit from freezing.
