littleredstroker
This is going to be kind of a budget build. im not looking to spend 5k but if it needs to be done I will do it.
the motor Im looking at is a obs 97-98 cant remember but it has the van turbo and the round exhaust flange.. dont know if that means much. its been sitting in the back by the barn for a while and I was going to look for a forged rod SD motor but I think this will work. It has somewhere around 150k on it and was in a roll over. has turbo and everything covered. So my question is this
I am going to pull the heads and see how the cylinders look. what should I look for as a idea if any machine work needs to be done?
What about the crank, should it need to be machined as well? what to look for as far as that goes.
gonna stick with forged rods Ive decided dont want more than 550-575hp
will probably replace oil cooler while its out
anything else to think about or look for?
