Rudy's sct sf3 review
here is the slip from me and the other 6.7 running torquetech tunes.
here is the scale ticket if anyone wants to do the conversion for me.. i googled a conversion calculator and what it told me and what i thought it might be was off by a bit.. it calculated above what i figured it to be...
Powerstroke Man 6.4
Weight of 8460 and 1/8th ET of 9.0293 and trap speed of 74.12 put into a 1/8 mile to 1/4 mile conversion calculator,
1/4 mile 14.12 converted
trap speed 91.91 and 8460 put into HP calculator = 445 at the rear wheels.
bigrpowr
<How I Fly
Administrator
lol prolly.. im stuck in the 1.90s 60ft with this truck and my dually.. i dont think its to bad for just tuned abd dpf deleted work truck. that weighs over 8k lbs.
what makes it so painfull to you?
just giving you $hit.
bigrpowr
<How I Fly
Administrator
14.11 @ 91.76
using the only calculator that is worth a $hit (MPH) its 443 rwhp . the e.t. calculator is always high .
14.11 @ 91.76
ok. close to what i figured it was.. now i just need to figure out why rail pressure tanks in the extreme tune...
can you add that calculator to the one on here?
bigrpowr
<How I Fly
Administrator
no its not our calculator. its at wallaceracing.com i take the calculated mph from the conversion and put that in our calculator .
best slip so far running the performance tune. manual mode 2nd gear launch shifting at 3500rpm. staying in 4th through the beams.
First track I ever raced at. Have a Ton a family up there.
right on!
dont know if i did it right but i did the Wallace racing conversions for 1/8 to 1/4 mile et and mph and input it to our hp calculator and its saying i made 471hp at the weels..
can someone double check for me?
