Single turbo info
Kedstrokin
Moulton TX
I've been looking into a single or a RCD 75 atmo. My question is if you lined up two stock fuel trucks one single 66 and a 75 atmo lets say the one with the 75 has a spartan 350 tune and the single 66 has the highest gearhead tune witch would win?
Cknox121
Augusta GA
See below
the single truck........
This!
The 75 might have the jump, but when the 66 lights.... Let's just say it's ****s and gets. Well I should clarify it's pretty clean with gear head tuning.
bft blue oval boys
Burlington, NC
Damn you people.... I had my mind made up on a drop in atmo now ya'll are changing it again
Sent from a Cummins plant, driving a Powerstroke, with a TDI on the side!
3brorce
Who's kit is this? Also, drive pressures should be way down with the single too.
Delaware6.4
I am doing the h and s kit as soon as they take orders and doing a single 72. Any of the main tuning guys are so good at tuning the 6.4 now that I am sure it can be dd with no issues.
Cknox121
Augusta GA
On a side note, thinking after these 35's wear out, I'm going to drop to 33's.
Should help with the single set up and keeping it spooled, hopefully not bog out on the highway as well.
Kedstrokin
Moulton TX
I'm trying to get that stuff together now my 37s are getting bald. So I'm gonna drop it down and go with 33s then Save for the single kit.
Cknox121
Augusta GA
And up grade boots lol, fourth time it's popped off, even with hair spray
CT9AIX
MA
so were probably talking low-mid 50's @ WOT. if you happen to do a full out run see if you can monitor boost and ebp. I know the drive psi is damn near 1:1, but I was just curious as to what it actually is for this set up
Cknox121
Augusta GA
Yessir. I'll have you a video in a little while.
BFT
southern cali
Seems like once factory boots stop holding they need replacing. I lost a clamp on the highway because of this
