Spooling s366
04cr450
harford county, maryland
How was smoke output with the 205/64.5 combo? I've got a set of 205/100's sitting on the shelf that I'm trying to figure out what to use for air. Was thinking the 64.5 sxe or the 66sxe. Spill on the 64.5 would be awesome I just don't want it to be a smoky hazy pig.
it was no where near smokey. The 64.5 flows as good as a box 66- it cleaned up the 205's with just a slight haze on a full fuel tune (which what u want, a slight haze). The 69 now different story, cleans up completely like a stock truck tuned. The 69 has more lag though so it will smoke pretty heavy down low if punched. The 64.5 if you would do the same would smoke but not smoke a heavy black smoke due to it spooking up so quickly if that makes sense
Strokethis213
I think I'm going to order the 66 sxe with 75% nozzle. Is it a pain in the ass changing the nozzles?
shmoozer
Makes perfect sense. I'm thinking a either a 64.5 or 66 sxe. Perks of a T4. Don't like one, change it for another. I'd need a larger set of sticks to feel the need for a 369.
04cr450
No they are not hard (nozzles) but I would send them to holders to get changed. This way he can go over the internals and give the injectors a final blessing before you install them.
For a 369 I'd guess an injector of a minimum 100% nozzle. Cc's you make the call(at least 230-250?) since the tuner will tune injectors from the nozzle size mostly.
Strokethis213
They're warrens injectors like 5 months old. Issue I face now is I work for 3 weeks and then come home for a week drive the truck then it sits for another 3 weeks I just don't want stiction issues or any issues with it sitting for that amount of time
HOOV3R
Central PA
I don't think you need that many cc'a for a 369. Hell, I can get close to pushing mine out of its map on a reduced fuel tune. That's with 205/75s.
04cr450
That is why I put a question mark after the cc's. Just judging on how my setup acts on top end. Maybe you are correct. 205's might be the max for efficiency
shmoozer
Do think 100 nozzles would be a little better suited for that charger?
Trying to learn and get as much info as I can out of these threads.
STRAIGHTSTROKEN04
What are your guys thoughts on a barder s366-sxe and 190/30's good combo or should i run a 75 or 100% nozzle ?
Strokethis213
Do 75s I'm in this issue right now were I'm gonna send mine back out to get 75s put in and I'm getting the sxe ordered this week
Strokethis213
Should I spend the 1600 on a fuel system reg. Return and pump or put the money else where
STRAIGHTSTROKEN04
Which turbo did you decide to go with ? I would do fuel system and regulated return to keep those injectors happy. Along with a fuel pressure gauge if you don't already have one.
Sealeveloc
Berlin MD
IMO yes you are going to want a RR and larger fuel pump if you go larger than 190's. But Im pretty sure you can build one for around a $1K
Strokethis213
Yea that's what I'm thinking and I want to get rid of that ugly ass fuel bowl
