SRP1
Tom S
Is this discontinued? I heard something along these lines today but it was not for certain.
Bean
That would be news to me, of cousre it always seems I am last in line to hear things.
We have had a few that had issues but not like everyone one we sold has gone down. Maby 5% rate, would much rather have 0% but its not a horrible #.
woodduck97
Maryland
Bean have you seen any pumps with cold starts with a extreme romp and after sitting for a few minutes after engine has been up to operating temps on start up romps hard again?
OBSWIZ
Wellington NV
We have 5 left to sell...
if your getting romps..check the IPR..clean or replace
Check your HPO pressure at idle..
woodduck97
Maryland
Brand new IPR. I have power loss with the truck as well. Truck with a 15* oil pump runs faster then mine with stealth.
94.5 Stroker
Lincoln, Nebraska
After being in my truck only six months and 10k miles, had a snap ring failure. Ended up loosing alot of oil and fried a bearing in the hpop. They rebuilt at there cost.
woodduck97
Maryland
Matt's tuning. DC 37% ICP 2890 at WOT. Same chip on Black974door's truck with stock 15* oil pump runs DC 41% ICP 2600 WOT. His truck will lay out more smoke and faster then mine with the same tunes and less mods.
Tom S
Thank you for clarifying that. I hope the speed bumps can get smoothed out.
mattman347
Readyville TN
I would say your friends truck would lay out more smoke with a lower ICP. The problem does not look to be the pump with the numbers you posted.
Wackerjr
what is the difference in icp and dc at idle... that is where you should be looking..... wot tells you nothing there....
Bean
By those #'s its obviously not the pumps fault your truck is slower. There is no smoke that gets let out, its only a mechanical pump and you can tell its condition by pressure and duty cycle. The pressure and duty cycle you posted means the pump is pumping plenty of oil to feed the demand f the injectors. There are about 100 other things that could be different from your truck to your buddies truck, for instance just take a peak in the tuning thread in the 94-97 section for one possibility.
golfer
we've had good luck with the SRP1's...
I'm sure Gary will get things sorted...and he has a very good dealer network...so any customers having issues should be well taken care of by his retail dealers.
