smokinstroker
What numbers can be put down on stock fuel?
Not looking to spray the truck.
Lets keep this one on track
i did 723
Mike, what were you running to reach this? High powers? Supporting mods?
high powers, airdog, and fuel bowl delete. valve train and studs. transmission.
My truck trapped 109 at 7780 pounds so I'm makin around 680hp according to that. That's with elites 72 and stock tranny.
This might be the way to go instead of adding fuelers and nozzles...
Touché....add air and be done. And if you want more power you can add any nozzle you want up to 110s
Just do a 71 or 72, it will be a night an day difference in your setup
Well from what I'm seeing holding rail with anything over stock nozzle becomes luck of the draw.
