BFT
I had a 8700# CCSB on 18x37's that went 12.7 @104 with JD behind the wheel. Fuel bowl delete, AD165, ported intake mani and HP turbos.
I'm saving my $$$ for another set of HP turbos
This makes the idea of adding fuel fly out the window
I want a clean reliable 650-700 smoke free just makes it 10x better with all the damn cummins idiots around here.
From what I've been told the added air should help with the rear cylinders cracking as well ( could be totally wrong here) but I'd like to keep from building a bottom end if possible :doh:
One of the funnest trucks I've ever driven was Godzilla with stock fuel and High-Powers. Stupid fun!
An alternative would be Tow-Power X's also. Slightly less power but 700+hp capable no problem. An intake manifold is well worth it. We saw the gains on the flow bench for sure.
So more than likely ill stay stock fuel. A z max manifold will go on regardless of turbo mods along with valve train.
So the question is tow x or high power?
Will tow x get me 700 without driving to hard? Price jump is quite a bit
I'm with you changed my thinking forever on turbo sizing
i believe what dustin is referring to is efficiency and the bonus effects of that.
spoolup=much better than stock
power= triple that of stock
temperature= incredibly cool, never over 1400 thru the traps
smoke=non-existent other than a puff at launch
efficiency=one fun as hell street truck that sounds like a god damn jet.
Whats the specs on high powers?
An thanks for the clearifaction mike!
76/62 bb
