Stroke this!!!
strokethis_06
It still has stock rods. Would like to keep them in the block. At least for now. I have thought about it more than once.
strokethis_06
ICP voltage?
Read from where? I am reading pressure from obd port. Wont go above 1450 or so. Ive heard this is cauused by the tuning. The way it pulls and smokes there is no way its only 1450. I plan to piggyback a pressure gauge off of the icp sensor.
Pizza pig
MD
the lower than icp the more it will smoke, it wont atomize as well. Need to read voltage at the icp sensor. Whose tuning?
MorganY
college station, tx
Get a look at ICP voltage. No need to get a gauge. If you can read psi on whatever unit you are using, most likely you can read voltage.
Josh@DirtyDiesels
PA
This is a post from PSN posted by Eric...
"1.0volt@580psi, 3.22volts@2520psi
(PSI) (MPA) Voltage
0 0 .02v
200 1.5 .4v
400 3 0.73v
600 4 .96v
800 5.5 1.2v
1000 7 1.4v
1200 8 1.6v
1400 9.7 1.9v
1600 11 2.1v
1800 12.4 2.3v
2000 13.8 2.6v
2200 15.2 2.8v
2400 16.5 3v
2600 18 3.3v
2800 19.3 3.5v
3000 20.6 3.8v
You can follow the trend to 4000psi."
