superchargers???
Hotrodtractor
Mingo, Ohio
If a supercharger is mixed in, I don't understand why it's not the second stage. Then it can never get in the way of anything as the CFM flow in that case wouldn't have ANYTHING to do with the turbocharging, and the turbocharging would simply treat the engine like it was the displacement of the supercharger.
All the calculations are perfectly straight forward and no valving is needed whatsoever.
I believe that most of the reasons are heat and force related. I've read some things indicating that some designs do not like hot air and I've read some things indicating that the extra pressure of being fed at noticeably higher than atmosphere pressures can cause detrimental deflection. Now this is all just reading things on the net because if its on the net it must be true, BUT I can honestly believe that there are certain supercharger designs that have these flaws - I've just never taken the time to investigate further because... well.... 2psi at idle. LOL Beyond that - I agree 100%.
Charles
Yet the same basic compressor being driven by a turbine instead of a belt can take in not one, but two, three, four or more stages of pre-compression...
Sounds like supercharger guys need to learn how to build stuff.
Hotrodtractor
Mingo, Ohio
Don't disagree with the basic premise that it should work, but being similar does not mean being identical in capabilities.
Besides - 2psi at idle - I'm good. :D
Charles
The drive is the only required difference. Maybe someone should send a mid-frame Garrett to every supercharger manufacturer just for them to take apart and learn how to build something correctly.
faster6.0
unfortunately im with charles on this one. the supercharger is going to light first. Id like to see a f1c or bigger procharger to light it off the line with one t6 single feeding the inlet of the p/c
rossypho
heres the question with vgt
how did you controll it. the 6.0 and 6.4 use differnt system, i belive the 911 uses a throtal position to open and close the valves correct?
i also still quite young and learning everything about air and pressure but you really cant make a turbo boost without a load correct? just like if you put your car in nutral and rev it your not going to see the 30psi you would see with normaly. so doesnt that prove that the super would compress the air no matter what, the turbo might be at 2psi but how fast does it spool? most supers actually decrese the time it takes for the engine to hit make rpm's (at last on gas cars they do) please correct me if i am wrong.
Hotrodtractor
Mingo, Ohio
The VGT positions are programmable via the factory engine computer in the truck I am talking about.
You are correct in a sense - the adjust-ability of the VGT allows us to tighten up the housing on the fly and create "load" per say - the turbo reacts to how it is tuned and it spools instantly making 5psi of boost just off idle - this is when the vanes start opening up a little bit to just maintain a nice crisp throttle response. Cruising down the road under most circumstances it makes about 8psi at 65mph unloaded and about 18psi with a trailer on the back - you push into a bit and it almost instantly makes all the boost you need. It is a VERY responsive setup. There are many on this forum that have been in the truck and even driven the truck that can back me up on how it runs.
Now that being said - I'm changing the setup around right now to make more power and I am hoping that the new bigger setup is just as responsive - but like all things it takes time to dial it in and it might be a while before I have it back there - most of this is just good educated guessing and a willingness to recognize issues and tweak accordingly. I haven't posted all the details about it yet - but you can read up on the transformation of the truck (even though it isn't a Ford) HERE.
Extended Power
If you were to put a 80mm T6 on top of the 6.0L, and have the charged outlet air feed into the Procharger...wouldn't you still have instant off the line boost, and then once the T6 spooled up the only problem I foresee is the T6 over feeding/pressurizing the Procharger case.
Or do they both supply the same amount of CFM?
And if they do...what's the point of running the turbo portion of it?
I'm not sure, but I didn't think prochargers liked to be fed pressurized air. IDK.
Would be cool though.
strokin6L
Springville NY
Yeah i think the same Ivan. If you look at Empire's procharger setup...they have the procharger feeding the turbo, not the turbo feeding the procharger.
http://powerstrokearmy.com/forums/showthread.php?t=1531&highlight=procharger
rossypho
i dont intend on running a procharger. again a procharger is designed like a turbo. giving better boost and cfm at higher rpms. its a mid to high powerband supercahrger
i want to run a screw or roots style. more reading brought me to 6-71 and 8-71 superchargers. while the 6-71 was diesnged as a diesel application the company talks about nothing more then 10psi in gas motors being a limit and how compression ratio is key. unlike diesels this is not the case. we can run 21:1 Compresion ratio and be ok. ie 6.9/7.3 idid (yes i have a 6.9 with a ats turbo and it works great. memery severs on the 21:1 ratio
now the roots style supercharger (6-71/8-71) actually doesnt compress the air in the supercharger it compress te air in the manifold, while the scre (whipple) compress the air before it is fed down into the manifold. again this is form the company that bolts the superchager to the manifold liek i was originally going to do. but now i want to feed the air to a turbo. so that mean the roots 9-71/8-71 superchargers may be the best bet. i was worred about a 60psi system blowing a SC up. but since the roots actually will compress the air between the turbo and the SC this means it should be capable of 60psi without hurting it. also with the roots it said id you are to over spin them (gas models running 6k+ rpms) that the air will heat up and actually making it act like a NA motor (from my understanding is the hot air expandes and i assume (drops the psi rating) even though the SC still spins and prushes air. all its doing is forcing more air (but not compressed air) into the cylinder. so een if it was to max at say 3000rpms. it wouldnt give the turbos more air it woudl give it the same amount of air that the turbo would normaly feed if the supercharger wasnt there. iv been looking around the 6-71 and the 8-71 would cost me about the same as a 4.0 whipple and seam to be a small high unit and feed form the top of the SC. granted screws are more effesent then roots i like the idea of roots more i read about them. also the current duaramax in the diesel mags was running a 8-71 or was it a 6-71 i dont have the mag in front of me and it seamd to work well . i think i might try the 6-71 due to i the fact its a tiny bit smaller and i dont want it to be underpowered at lowe rpms. i dont care for the sc at top cuz a big turbo is what will produce that power.
also on the fact about how much energy it take to spool a sc vs a turbo. research shows that a twin kit (current diese tec mag) say a ats 5000 turbo will produce said hp. when switch with a ats 3000 and ats 5000 the boost might have been a couple psi higher but the hp was dropped. due ot the fact that turbos are not free engery and require so much hp to spin. so the way i see it 1SC and one nice sized turbo should yeild in the same hp loss but will creat better off the line proformace.
now with the vgts. what to say i couldnt run a properly sized vgt with a turbo
this should provide a good lowe boost at cruise and the max psi when at wot. yes?!
the procharged kits from empire ran a PC and the stock 6.0 turbo. i know my truck doesnt really feel like the turbo hit max till 2000rpms anyways but iv never really seen what the top enf proformace feels like past about 3000rpms. (only drove mine for under 2weeks and didnt play with it much)
i am realy thinking about playing with the idea and testing this out with a 6-71 and a stock turbo jus tto see how its sized. maybe tryign out new turbos with wastegate and blow off valves to make sure i wont drestory everythign during testing. theres not much info out there. hells there not much on the PC let alone dyno spec's. the reason i want this is cuz i spend most of my time babying my truck. never letting it hit high rpms. i love racing at lights and all i want is to beat any ricer and most corvetts and mustange at lights, why you ask because i am still very young and like to do that kinda stuff. i am looking for something that will provide me with the most amount of tq at bottom end and SC is the way to do that. also i like different, and to be different. im not afraid to test thing out and if all fails. ill buy or rebuild my 6.0 and probably just try compunds but i want to try and be different first. i i love going ot car shows with smethign different, i always have *back in highschoiol i had a 71 baja louder then any vett and the local burger joint car shower every friday night. one night we went mudding with my bro and his jeep. showed up covered in mud and they all wondered how a 7in clearnace bug could handle what a 4in cj and 31in tires could handle, i said becuase hes only got 7in of clearnace from ground to diff. my car weight maybe 1200lb totaly his weights 3k. i might have 60tq but i have no weight to sink into mug, and my all terrains worked in the top side of the mud. i also cleared the trails faster then he did. im just into things that make people rethink. if i can have a supercharger and turbo charger truck i can just throw that into muscle cars faces. most vetts were i am from will run turbos cuz they provide better top end, but they all envy SC classic and whish they could get top and bottom end. thats what i want, and i want to throw it into there faces and say i did this from scratch not just throw a kit on
rossypho
heres something interesting. what about fords new turboo??? that sequentail single twin thing?
anyone got the spects in sizes??? i could be possible to try and get a 6.7 guy trying to upgrade his turbo and buy it off him and try and throw that in. i mean its a small and big turbo. could run the sc to the big inlet or to the small and feed a normal air filter to the other one and see how it handles. just a though i know nothign about these turbos nor do i know if it woudl work
FaSSt9602
Gilbert, AZ
It is already a limiting factor on the 6.7 so it wouldn't be worth the time to try to get the electronics to run the thing.
Powerstroked162
On Da Juice
Wa. State
How old are you kid?
rossypho
ahh see i didnt know it had electrics. just something that was brought up though i would just bring it up
why is everything always about age?? is this another your to young speachs i am about to hear? 20 btw, if it is please leave it to yourself i truly dont want to hear it again... so annoying
Charles
The efficiency of a traditional blower like you are referring to here is HORRID. Bare in mind at all times, what you are trying to achieve is not pressure itself. Pressure is just a means to allow you to increase the density of the intake charge. If the pressure is completely offset by enormous increases in temperature with a stupid flat-faced rotor slapping against the charge air trying to push it out, while it rushes back in, beats the sh*t out of the rotors, so on and so forth, then you're just chasing your tail, and eating up a LOT of horsepower spinning the wee out of the damn thing for tiny gains in actual density...
Yes. The classic straight rotor supercharger is simply a pump. It pumps X volume of air and "stacks" it up in the intake manifold where it compresses at the discharge of the unit. Horribly inefficient. Try like 40 to 60%.... maybe...
The "whipple" is actualy what is called a Lysholm type compressor. It uses screws to gently compress the air along their length. This produces a much smoother compression, and allows for a much smoother introduction of the airflow into the engine's manifold. Instead of a constant beating with hammering pulses of flaming hot air, the lysholm sends a smooth flow of air out the screws. This is also why they are so much quieter.
If you are talking about placing the unit ahead of the compressor inlet of the turbocharger, then I just can't see this being a smart move. The supercharger is only going to move X CFM per rev, while the turbocharger will draw a wildly varying amount of airflow depending on engine power output and engine rpm. In other words, if you placed a boost gauge between the supercharger and the turbocharger, it might read out 5 to 10psi off idle, and with low throttle settings right on up to higher rpm. But as you started standing on the throttle and exhaust energy started going up as more fuel was introduced and more energy went across the turbine, the turbocharger would start building boost of it's own, in essence making your ____ cubic inch engine 1.5, 2, 3 or more TIMES that size in terms of the CFM flow into that turbocharger compressor. When you got on the pedal, you could actually watch the boost gauge between the blower and the turbo drop to zero if the turbo was even moderately sized and you had the fuel flow to support it. If you had a boost/vac gauge, you could probably watch it swing to the vac side...
I would never place a constant displacement unit ahead of a variable displacement unit. No dice. It's just going to get in the way.
This is the horrible efficiency of the units. When you overspin them they get so inefficient that the heat offsets the gains through pressure and leaves you with nearly the same density, but with much more heat and pressure. Pretty much the worst thing you can do to help the engine out. Same basic amount of oxygen coming in, but more pressure and temperature to try and tear things apart for no good reason. It doesn't move any more air, it just beats the sh*t out of the air it's drawing in so much that it heats up, makes more pressure and sends flames out the discharge.
It's actually more likely that the turbo would be worse off once it was up on boost trying to get air through a restrictive intake air heater.
You need a lysholm type if you want to make power. If you want something for nostalgia, get an old weiand. And a larger blower is only going to make more low end boost when pullied the same. And if you place the supercharger ahead of the turbo, it has every chance of completely stifling the turbocharger to death, killing all the top end power it was supposed to make because it's pulling a vacuum through a flame thrower.
Obviously if the engine could support the 5000 as a single, then adding a smaller turbo was only going to help broaden the powerband, not make more at peak...
Now if they compared the engine power with a 3000 as a single, vs the 3000/5000 compound setup they would have shown something worth seeing.
The turbine makes use of thermal energy that the supercharger throws down the toilet. The hp loss will be greater. And off-idle performance is only limited by the strength of your bottom end on a well sized and tuned turbocharged engine.
Yes.
There's really no need. All you will do is punish the engine, spin the tires and then fall on your face when it really counts. A turbocharged engine would come out of the hole just as fast, and then leave you like you were sitting still up top and continue to pull away from you when it mattered.
If you just want to fry some tires at slow speeds and act tough, then what you're describing will probably pull the wool over most people's eyes.
I think I might get you to rethink the love affair with torque for starters, lol.
Pumping the turbocharger into a lysholm type compressor then into the engine would make more sense to me.
But good luck whatever you try.
rossypho
there suppose to have been reasearch on a turbo spinning a PC and a PC spinning into the turbo. supposable the PC to the turbo was better.
yes i understand the roots style is less effecent then a screw. i understand this very well. what i belive is the SC would be better off producing higher boost if all the compression it makes is outside of the SC like the roots does. (again screws compact the air inside, and can only hold 30psi set by the manufactuar) now a roots since all the air is being compressed out of it the unit it should be able to produce higher psi without hurting it. im not trying to overboost the SC i understand it will be bad, im trying to compinsate it with a large SC the 6-71/8-71 blowers were disgned for diesel and yes there the weiand brand btw. what is this nostalgia you speak of?
my original idea to SC my truck isnt going to be a great idea. when i finally get stationed back in the states (1 year) ill should have had enough research to start getting parts togeather. but the original idea was to buy a 06gto for a fun auto x, drag kinda sunday car. yet the amount of money i want to put into that and then still be trying to SC a truck just aint going to happen considering other things going on. so my new goal is to find a 03-07 single cab (or any 6.0) thats just a abused work truck that still runs and doesnt have major probelms. (injectors can be bad, head gasket can be shot, due to the fact all must be changed to run big injectors and all that) by major i mean like destroyed internals, i figure get a cheap 6.0 to test everything on, drive mine daily like i plan and once i figure everything out, just do a parts swap and then maybe do a test from that abused 6.0 with twins and see what a motor that had a sc turbo mod and a twin mod with both dyno sheets (i mean of course later down the road when i want to prove the sc) just to see witch on was better. but overal its not about peak hp. again i dont like runing high rpm, i like driving and launching at lights. yes you can launch a twin turbo and make boost form a dig with nos and all that drag stuff. but you just cant nos at everylight all the time. i want something thats just fun to drive and i love projects, i love being different, most of all i love turning wrenchs and tinkering with motor.... hummm wonder why i pick a mechanic job in the army! not trying to bash here, not trying to say im better by any means if that cross' anyone mind, i just dont want to hear anythign about age please. yes i am young but iv been towing with engine for a while. again kept a 72 bug running for 4years stright on a highschool budget (granted cheapest old car to keep running but i did really abuse that motor) and i also had a 6.9l idi that wasnt in the best condition last 1.5years of highschool. and it held up till the wiring harness really took a dump. i am by no means unskillful. age is just a number, i am just trying to nit pick people with better understanding of how turbos and SC systems work, because its something new to me. i ask a lot of question and i am not afraid to look dumb by asking "hey could this work". i will take all negative and positive feed back as long as its construtive to this build. thanks for all the input please keep it coming. also i am still searchign for dyno PC and any SC diesel running around. on a 40something od page forum about PC P.S right now, reading every word trying to see what its all about. still trying to see if carl will get better info (soon be dynoing his 2.3whipple and turbo so he said) again i am not to interested in the total number more into the power curve, the big turbo woudl make the power as long as it would be the same big turbo in a twin/compund setup
Charles
Probably not better, just easier on the pansy little pc that's scared of heat...
First off, that boost number they give is related to the pressure ratio that they feel comfortable with their unit handling on it's own. They are not giving you information meant to apply to total pressure in a multi-stage system. A lysholm compressor putting 10lbs of boost into the engine will continue putting exactly the same boost, and running exactly as it would by itself if you fed it air from the discharge of a turbocharger. And the turbocharger would be sized as if the engine were the displacement of the blower accounting for blower efficiency, and it would work exactly as such, all the way from idle to the rev limit and at every throttle position. The blower wouldn't care that it was being fed air at 14.7psia or 40psia, it would still move the same displacement and make the same pressure ratio.
If you reverse this, and put a positive displacement blower in front, then the pressure being fed to the turbocharger will be high at low throttle positions, and drop to vacuum under full power, and in either case you'll only be moving what the supercharger displaces, so you might as well either get the supercharger out of the turbo's way, or stop wasting time with the turbo because it's doing nothing but making a decent muffler for the exhaust.
And nostalgia is when you choose something, not for functionality, but because you like the sound, the look and most often because it reminds you of something you enjoyed in the past. Using an old straight-rotor supercharger should only ever be done out of such reasons, as in terms of functionality, it just can't compete with anything anymore.
rossypho
ok so what your saying isa screw SC should be able to handle boost even if the truck see a totaly boost pressure of say 60psi at max rpms? correct?
now lets say i put a 4:1 ratio from engine to supercharger (4000rpm motor speed should equall 16000rpm SC speed) that means i have a 24L motor yes. so what sized turbo should be added to the eqation? is this what your refering to
"And the turbocharger would be sized as if the engine were the displacement of the blower accounting for blower efficiency"
Charles
Yes. Although I doubt the blower would actually function at that rpm, but if instead you perhaps used 4 of them all running a 1:1 ratio, then yes, the displacement of the "engine" as the turbocharger would see it would be exactly what the blowers were displacing. In which case you would need more than one turbocharger in parallel to meet the need, just like you see on actual 24L engines...
All of which is obviously academic as the resultant manifold pressure would tear the engine block into pieces, and the pressure ratio the blowers would have to run at that displacement into a 6L engine would probably be outside their abilities anyway.
rossypho
why do you say a blower wont function at 16000rpms??? this is exactly what the manufacture said it will do. think about the typical camro vet build 6500-7000rpms on a charger running a 2:1 or ushally a 2.5:1 ratio. ???? see why i wana run a 4:1 ratio cuz it can be done granted most SC dont do well at that rpms but my truck also never see that kinda rpms so im no worred. i dont ever like going above 3300
