Justin@DP-Tuner
- Joined
- Jun 22, 2011
- Messages
- 2,170
- Reaction score
- 0
Just Google "Dorman 699200". There are a bunch of places to order the accelerator pedal position sensor online.
Well guys I hate to bring back old threads but I still havent been able to solve this one. I replaced the TPS and that seemed to solve the problem for a little while but its back now. I asked some friends and they said to change the cam sensor.. which was really easy to do once I had to replace the water pump unexpectedly.
Anyway it still cuts in and out, not as much when I'm accelerating but it gets pretty bad when I'm trying to maintain speed and it almost always cuts out quickly when I back off the go pedal. I thought I had it narrowed down to the chip being a problem but it does it very subtly without the chip as well. I unhooked the ICP sensor and drove around to no avail.
I'm out of ideas guys....
Thanks
Have you looked into your IPR?
Check the IPR harness connection, and also the nut on the rear of the solenoid portion for looseness.
have you cheched fuel and hpop pressures?
Was the TPS a new one? How did the harness connector look?
I looked around under the hood and noticed that the wires going to a connector were rubbing on the drivers side valve cover and had worn through. I used some electrical tape and taped it up so it wouldn't rub but I still have the problem...
The big square connector for the main engine harness? That could be a problem.
ahh... 'scuze me..
change your fuel filter.
You are gelling.
Did that too when the water pump went out. Same before and after.
is the bowl heater working?
got a Wicked Wheel in the turbo?
