thick milky residue in coolant reservoir possible Causes?
NRHX2009
Elizabethville, PA
A friends 6.4 with 86k has a thick residue in the coolant reservoir. Its consistency is like pancake batter. Color, thickness and texture. I drained the rad and reservoir into a tub and the stuff stuck to the side of tub. Oil contamination? I will post up a pic soon.
Wemoy1
PA
Oil possibly mostly when oil is in the coolant system it will black most of the time, ive never worked on a truck that had that color in it.
TyCorr
How often do you cr guys have to rehab your oil coolers?
Mine is getting its.third rebuild at 265k.
Dzchey21
wyoming
Just depends on quality of the coolant more than anything.
Seams like they are about a 100k cooler tho...
Big Angry Hillbilly
I'm gonna chalk the plugging up to the coolant. Ever see the oil cooler on a maxxforce 11? Same ****. Different antifreeze. Never see them plugged and we have tons of em at work.
TyCorr
I meant the guy that's on his third one lol
My trucks 13 years old, lol. If I.wasnt maintenance whore it'd be more problematic. Its a totally different truck, I read a lot of.threads outside the 7.3 tech and I was curious if oil coolers are any better in newer trucks. Problem with the setup on mine is the orings get old and brittle and the cooler will get leaky or if not that you'll find milky sludge in the coolant. I did my water pump and coolant and found said crap so I ordered the rebuild "kit".
TyCorr
Figured in the 6.4 section you'd be talking about a 6.4
Nah, we have to rebuild alot. Wondering if you guys had the same issues? Apparently, so. Given the information in this thread that oil cooler failed, at a fairly low mileage. Id like to see the coolant that was in that truck.
