Time to upgrade turbo
ChattyCathy
Do you think it would be worth going with compounds or just a single?
There are rumors that at some point H&S will have a triple kit out. These truck run really really good on a single. I personally have passed on dual fuel since my truck runs so good.
It all depends on your budget and what you intend on doing with your truck as well as a hp goal if you have one (I'm noticing many people don't have a power goal in mind and just want something that drives well without worries). If you're wanting up to 700 hp there are single options available for sure. We will be offering our kit with 64.5, 66 and 69mm options in addition to our current 64. Those turbos will range in horsepower between about 550 on stock fuel and 700+ with a dual fueler. Beyond that power, you'll be looking at building a motor and trans to remain reliable.
Hope that helps!
erabbit4192
Michigan, living in jacksonville NC
erabbit4192
Hope that helps!
I have a 700 horsepower I'm mind. When will your guys new kits be coming out ? And will there be some of package with the dual fuelers?
If 700 is your goal, that's not too difficult on a single and still drives well.
Kits are nearing completion as we speak. Hoping to have an official release of those and a handful of other parts shortly.
dsmracing1
Alberta, Canada
stevens6.7
Houston
That was helpful thank you. Sounds like single is the way to go
No problem man! The guys at H&S seem to have some great products and between Dallas and Mike they will set you up with anything and everything! Looking forward to see what you get!:toast:
erabbit4192
H&S is what I'm having in mind right now. I might wait a bit and see what new turbo kits there coming out with and make my final decision from there.
ChattyCathy
Good thinking. The 64 Pius charger is pretty sweet charger. I wouldn't change it out for 50 HP. But that's just me I suppose.
Athens, IL
We have some setups that will make 700+ while towing, still retains exhaust brake capabilities, stock driving manners and also has a bitchin powermax-like turbine whistle. Would be glad to set you up with any dual fueler/turbo/injector setup you could possibly need. That combo is just so fun to drive being effortless to drive with smokeless near instant on demand power at your right foot. Pretty cool to be cruising a long, floor it without waiting to spool the turbo, and just boil the tires off.
erabbit4192
Thank you Morgan. That's exactly what looking for. Any new turbo options coming out from you ?
