TheSmokinStroke2002
Oh, that SUCKS!!! :doh:
tell me about it :doh:
Does anyone have any opinion on using a shift kit to band aid a transmission?
being that the transmission only acts up when warm, would that be a good sign of bad clutches?
Is it only acting up when warm - or getting warm when it acts up? Burnt clutches slip and slippage builds heat. All that crap in your oil - thats clutches. Its in your cooler and cooler lines, its in your valve body - its just sitting there, building up, reducing flow, and possibly going to start causing issues beyond just clutch slippage.
Hope that helps after your PM.
Hopefully the cooler and highway cruising will allow it to get ya home. It'll be a mile from home when ya have to stop and run through your gears that it will start acting up.
Then it wont start the following day....
156K. hasn't had the easiest life by far. it has been tuned for probably 30 or 40K now. started its life with a bully dog for 10K then custom tunes. scary thing is that it was acting weird when i had the bully dog so i guess if its made it this far i cant ask to much more out of it :dunno:
Mine went out at 162K and after researching that seems to be the milage the 4R100's like to go out.
