total loss
02BigD
Coastal NC
I run a billet wheeled 71mm h2e
71/? out of curiosity....
I'm also curious if anyone is monitoring back pressure with the 68? Seems like as low as it's spooling, maybe contributing to higher back pressure at WOT?
97stoker350
south central pa
my bp gauge has never worked right but i believe it was around 50-53 at the most. nothing extreme. it has the 83 turbine and 1.10 housing
m j
BC Canada Eh!
Not at all. It's the 68 and the 200 nozzle matched up in a cylinder. Boost comes on early, lots of fuel, rpm and cfm, too much pressure on rods
IMO that is not what happened on this motor.
the broken rod is not a compressive failure (would be bent)
it is a tension failure. piston went up but didnt come back down with the rest of the rod.
if it was too much cylinder pressure it would have been driven down in to the carnage
bruce
Middle east
I wonder if the big tires and 3.55 causin that rig to lug constantly aided in this destruction.
97stoker350
south central pa
Piston that went had Vavle slap and the valves pushed it howerever far down they go and that's where we found it so yes I'm guessing the rod pulled away
isootmypants
North Jersey
I'm thinking it was stress cracked before hand and it broke on the compression stroke, piston kept traveling upwards and contacted valves
97stoker350
south central pa
I was running it pretty hard and when I let off is when I heard the grinding.
Valve slap was only from the piston being left at tdc
V-Ref
9 miles high @ 550 mph
Sorry to hear your bad luck. Is this your only vehicle or do you have another way to pay the bills until you get this one back on the road?
Just my humble opinion...Metal fatigue is what broke his motor...I think he has a real well balanced and thought out setup, put together and tuned by good folks....stuff just breaks when you make power. It just sucks when it's your truck :) Billet rods/girdle/coated pistons blah blah...just move the weak point to your trans...or elsewhere in the system.
Build it back stronger than before!
V-Ref
With the 1.10 Turbine Housing, I was seeing 1:1 up to about 35 psi, then at 45-50 psi boost, I was seeing 50-60 psi drive. 200% nozzles.
97stoker350
south central pa
more carnage. chunks out of cylinder 4 is the one that let loose
Powerstroke Cowboy
Montana
I have 300/200 and a 66 that can light to 25 to 30 PSI before 2000 RPMs. and slip the clutch like crazy. Might be the life saver so far! LOL I try to keep my foot out of it.
