White_monster
Well in that case it's good to go. Didn't realize it was the same turbo in both sets.
Can't you adjust the lock-up speed with the H&S?
Good to hear brotha.
Thanks for the help.
Its coming along. I had to change the compressor housing today as well on the lp. It had a slight leak due to a machining problem. No big deal less than a hour with my traveling kit. It feels like it stalls out at times from lack at fuel. But like I said these are tow tunes. more will come with some empty tunes built.
mine with tight housing would stall on shifts and on converter lockup, but since going to the bigger a/r ...it basically went away. with the tight housing i really had to learn how to drive it, tow/haul was my friend until i learned.
