strokethis_06
- Joined
- May 2, 2012
- Messages
- 519
- Reaction score
- 0
Solid tan wire in trans harness.Ok what color wore do you tap into?
No. It needs to be grounded to lock. I just used the upfitter to supply power to the relay which closes and grounds the converter solenoid.Ok sorry about all the questions so I take a wire tap into the tan wire and run it back to my upfitter switch? Then wen I flip it it will lock the converter.
I will see what i can do. Its not hard.Ok thanks. I wish someone had a good wiring diagram drawn up. I
