I removed every line, one at a time from 4 spots... Had pressure all the way to the outlet of the filter...
So the filter could be plumbed backwards, or the filter is just to restrictive.
I had full on fill every bit of a 3/8" line until the outlet, then it just barely was coming out. More then a drain, but less then pressure.
DAMN will that pump move alot of fluid quick, I bet I have 3 qts in a 5 gallon bucket from just a start, run around and check and turn off 4 times.
Mark mentioned 1qt in 15 seconds, hell I would bet I would get 3 or more in 15 seconds.
Filter is bypassed for now.
