Transmission Pan tester
Zmann
My pan showed up today My it weighs in heavy at 12lbs
I will weigh the stocker when I pull it off
also it has a magnetic drain plug but nothing like the pan magnet on the stocker
I didn't read the directions yet but I recal the magnet from the stocker being removable and if so it's going to Migrate
Mike@MPD
Pasadena,MD
Fwiw I put a deep pan in my 6.4 and was running 185-190 put the deep pan and it did not get over 160. Now its a little higher because I am running whatever synthetic trans fluid brian uses in his trans
Sent by my Nexus powered by this (╯°□°)╯
Zmann
If u guys get this pan and are not reusing the old oil
you need 15 quarts to refill .. 14 put me at the cold mark when it was hot so I needed to open the 15th to top off
I drained about 8 from the stocker so it's is about 7 1/2 more quarts
I have noticed no cooler temps ,, but I never had a chance to compare towing or hills
so I imagine normal operating temps weren't going to be less simply because the cooler bypass opens at 170* so my avg temp of 175 wasn't going to be affected by this pan
i was able to transfer the big magnet out of the OEM pan but I had to shave some off one side of it to get it in past the tubes
Installer tip ,, just like the stock pan .. loosely install a couple of bolts to hold the pan
up
then do the ones near the cross member that are a biotch to reach
otherwise you likely be removing some to get the pan to wiggle enough to get those in
Tonka350
Melbourne florida
I was actually going to order one of these to see if it would help with my issues....as well as upgrade my cooler before I regear to kind of help.....we'll see which helps though, I am going to order one of these on Friday though.
Chad
