Morgan@Midwest Diesel & Auto
It's a pressure manifold. It has more than enough volume to allow for ample flow to each head.
This might have been asked already but what kind of BP are you seeing with that turbo?
He's said a couple months away.
So you changed yore mind on that.
How much EBP was you seeing with the 66?
What kinda time frame would these kits be available
Nope. I said its a pressure manifold.
Pressure = forced indictuon = different than vacuum flow.
In forced induction, volume, and restriction to airflow are more important than vacuum flow characteristics. Reduced volume runners that work well to keep velocity up in a naturally aspirated cylinder head will impede air volume when pressure is behind it.
Same reason we don't use the same log style pressure manifold intake on the 1000hp naturally aspirated big blocks we built as we use on the pulling engines we build.
This would run like a bag of diks on a NA gas motor.
But this doesn't.
Why didn't you do all that in the first place? More welds and boots was never a good idea. Good work though it is a much better design.
Honestly when I started I had an idea of what it thought would work. Each time I built a style and used it on my own truck it showed that it was lacking in some area. But the main reason the intake is the way it is is because the last style would not clear s400 frame chargers. And I wanted a universal piping setup. Plus I did want to ditch all the boots for simplicity.
This kit will not be as flashy as others out there. More budget oriented. Retaining stock exhaust manifolds was part of that. It will not be for everyone. Just an option.
And thanks.
