Turbo kit testing, what you guys wanna see?
ChattyCathy
Well if that's true then why do people get vgt's?
Simplicity, bad experience with a non VGT, personal opinions. My non VGT spools at 1300 to 1400 RPM at elevation and supports enough HP I would ever want in a single charger, however if It did not and maybe didn't spool until 1800 or whatever I would want VGT. But like everything people want different things ya know.
Cheap6.7
Rockisland County IL
Lit by 1300 sounds good to me.
So I guess tuning will play a great deal in this topic, I'm SCT tuned and finding the tunes for a non vgt is the problem.
Would the non vgt be make more smoke from a dead stop? That is what my impression was?
ChattyCathy
Tuning and the turbo ya. lots of variables there to say anything definitive.
Athens, IL
Overall you can spec a non-vgt to work very well. But the main limitation is using a larger non vgt to make a desired hp then suffers some on the bottom end. A vgt is more able to perform in various different scenarios, while not excelling in all areas, it can be a little more versatile. And exhaust braking is the other reason. I have both setups both for different purposes. And either one is great in its own right. All out performance a vgt will not hang with one of theses style kits.
gfulton
Eliasville, Texas
Hence the reason we went with a VGT........I wanted bottom end power..
