Twins for dumbies
Tree Trimmer
but didnt charles put the gate right into the housing of his 38r? and that would bleed off pressure exactly where you needed pressure bled off.
i dont know if it makes a difference or not, but to me, given the choice of location of wg placement, the housing would make the best place for it. isnt it the pressure in the housing that makes the difference, not the pressure in the up-pipe? if your bleeding off pressure before it gets to the housing, isnt that taking away from the available velocity of the exhaust. you lose pressure and velocity, as opposed to just pressure. granted, its probably comparable to spitting in a pond, but i wondered, so i asked.
^^i probably murdered the train of thought/choice of words in that paragraph, but im sure you get the idea.
granted, ease of installation/tuning, and available space come into play also, but given the option, isnt the housing the best place for it?
Big Bore
9000ft in the CO Rockies
Yes, but right at the entrance.
I disagree with all of that.
What i have gathered from set ups like brian's truck is the reason you run two gates is because a single big gate tends to dump pressure too fast, which can make the gate surge and chatter opened and closed, because the gate even opened very slightly is dumping a TON of air, i have no experience with it tho. but it makes sense, if you can basically open on gate wide open, and then start to bring a gate in at the higher rpm to blead any additional back pressure up top if the rpm range.
Im running a single 46mm gate for now, and then if i need more i will add another gate. I also like two gates because there is no real reason two tie both uppipes together (for flow reasons) where with a 60 gate you would have to.
Doesnt a stock type wg only puke from one scroll? I dont think that having a big gate on one upipe would be that horrible. That how I planned on doing mine actually. Unless Im not following you correctly!! Which is a possibility since I spent three g'd*(n hours at home depot today!! FML.
Big Bore
No what he is saying is having to tie the two up pipes to a single WG mount would be a PITA. Whic is why I think the guys running a single WG put it in the exh housing.
I would think wastegating one up pipe would cause some imbalanced flow in the exhaust.
It depends on how the piping is set up...because thats exactly what the stock setup does, really. The internal gate only bleeds from the one side of the scroll. I realize we're talking about gating different parts of the induction system but pressure will equalize itself either when the pipes converge or after passing through the housing. At least they do in my mind.
If you gated one upipe and the pressure coming out of that side, lets pick an easy number, 40psi, and the other side was making 65psi, you'd have one pipe meeting another at different pressure. It would equalize itself immediately after mixing.
Ha ha...I also think that if you're this far into being comfortable with fabrication making a "Y" to send both uppies into one LARGE gate would be fairly easy. I appreciate the input but Im not completely convinced that two gates would be better. Thats me though. Gotta question everything! :thumbsup:
Ill tell you this, a 60mm gate can handle the pressure cycles better than a little guy that is getting hammered by overboost constantly. There should be a way to dampen the larger gate to prevent shudder when it cycles. I may be approaching this all wrong but in the tuner world people had tons of trouble/failures running small gates. Brand matters imo too. Tial is THE gate manufacturer.
Big Bore
The internal gate was not designed to bypass the type of boost pressure we are talking about here. If it was, people would not be buying non WG housings and putting external wastegates on. However I believe the internal gate is actually bleeding off pressure from both exhaust manifolds
Big Bore
Thats why you use two gates, each of which has more area than half the single and it's only bleeding off half the pressure.
I agree, specifically because tial makes a water cooled WG, but only in the 44mm and under sizes.
Right on! I know that. Im just saying that at a lower pressure its doing the same thing right? I think its the physical size of the internal gate in the stock charger and 1.00housing for the 38r that makes it suck. There are pressure inequalities even in stock trucks. Do a wot run on a stock truck and let off...you probably will hear what sounds like a turkey gobbling. Pressure equalizing itself...
Take any charger and any non-wg'd housing add any size plumbing you want and gate one of the two uppies. What will happen? You might create a slight amt of backpressure on the bank that is feeding the wg. Or you might find that nothing is happening because that pressure equalizes when it comes into common space, like the uppipe collector. I would think a little backpressure would allow the gate to function more crisply too.
Ive not done this on a diesel and it may be way outta line with popular thinking but it makes sense to me.
This is one of the best threads in a long time!
Charles uses one 44mm gate. Its just barely enough. So if one were to go any bigger or not want to run a 44mm gate on the ragged edge a 46 would be much better. The 60 would be overkill even if you were dumping to atmosphere twice what Charles is.
I dont think lack of watercooling on the 46 or 60 would deter me from it.
psduser1
on the road
Tycorr is correct- by the time the exhaust gas hits the wheel on a standard 1.0 housed 38r, the scrolls are no longer divided. That's why there is one 18.8 mm wastegate, which is woefully inadequate! If you gate before that you'll have a pressure difference between the uppipes, but not at the wheel.
I can't say for a 1.15 housing, cause I don't have one, but Id speculate that its similar. Please correct me if I'm wrong.
That design would make a wastegate most effective when plumbed into a common space, per Charles, rpminc, etc. Less piping, more accessible, so on.
Closer to OP train of thought, if your primary turbo starts the boost, and guys with bigger housings mention slightly increased lag in a compound setup, would a tighter housing, aka 1.0, or even .84 housing minimize that. After all, your looking at a bigger turbo (atomospheric) to handle the top end. Properly gated, of course.
Btw, execellent thread. Keeping the brain cells moving!:thumbsup:
Dzchey21
wyoming
no im just saying that a single uppipe doesnt flow what the gate will
Big Bore
That should have read drive pressure.
Tree Trimmer
can someone show the math involved for a couple things.
in taking and converting lbs/min to cfm
in figuring out how much lbs/min the exhaust will flow at various rpm's
and how to modify that formula to account for different variables. boost, injectors, and the many other things involved with ending up at X lbs/min.
i can read a turbine/compressor map, but without being able to figure out what my motor does lbs/min wise, the maps are useless.
jkidd_39
NW Arkansas
You can go tighter on the housing but you need to look at your map and make sure you aren't going to choke out the turbo. If the housing is too small you also run the chance of making it too tight.. the turbo will spool super fast but be hard to control. And cause some wicked backpressure.
http://www.turbobygarrett.com/turbobygarrett/tech_center/diesel_tech.html
from what I am seeing in the twins game.. everyone wants to go larger than a cummins twins kit b/c of the displacement advantage. However the cummins has a better head design in terms of air-in vs. air-out. I would look into a smaller set up. Something along the lines of a 62/68 secondary over a 80 or 82/92 or 96.
There are others on her that have more experience with this subject than me.. but for instance.. Brian Jellich is running a 66 over a 103-ish primary..
V-Ref
9 miles high @ 550 mph
I'll try! I like references for stuff....Hope this helps.
Reference-Garrett Turbotech103
"Many people use Volumetric Flow Rate (expressed in cubic feet per minute, CFM or ft3/min) instead of mass flow rate. Volumetric flow rate can be converted to mass flow by multiplying by the air density. Air density at sea level is 0.076lb/ft3"
Since you want to convert the other way, just inverse the equation-
Ex1: 95 lb/min / .076= 1250 cfm
Ex2: 1250 cfm x .076 = 95 lb/min
Reference-Donaldson Filter page 7
(Exhaust Temp. (°F) + 460 / 540 ) x Intake Airflow(CFM) = Exhaust Flow
Can't help here. I'd be pretty critical of the credentials of somebody that says they were to ensure you weren't getting fact not fiction....as you're asking some deep PhD level stuff above...
There will be a small addition to the exhaust mass that isn't accounted for above because of the addition of fuel. The link below is speaking to gassers.
http://www.eng-tips.com/viewthread.cfm?qid=104735
If that chit right there don't make your brain hurt...well...umm...:wtf:
You'd need to know turbo RPM to accurately plot the performance of a compressor wheel.
Besides Charles/Gearhead/Tarm and other smart folks posts on some the of threads here and elsewhere, this link below is one of the best references I've ran across in learning how to read turbine maps.
http://www.dieseltruckresource.com/dev/do-turbine-maps-tell-us-turbo-t168543.html
I'd PDF these links...as I've already lost a couple good links due to forums going Tango Uniform.
I've got a couple book on turbocharging/supercharging too....but nobody reads those anymore :lookaround:
juniort444e
Slippery Rock, PA
I didnt even read that v ref. I went crossed eyed and quit.
Some good info in that tho. I love math and will try to figure some numbers out for my setup.
juniort444e
Slippery Rock, PA
Tarm im still having trouble finding the 4288 you were talking about.
But here are the two im thinking will work good together and that im willing to try. If someone thinks other wise please post why and what you would change. Thank you.
Primary is a Gt4094R w/ a 1.06 or 1.19 housing. And the atmosphere would be a gt5533 with the 91.2mm inducer and a 1.00 housing.
After looking at my engine bay and trying to imagine where i will put these i think i found a good solution that others have already succeeded at. Ill move the passenger side battery and stick it in there. But until i get the turbos and time and money i cant do much now.
