Strokersace
So I've put a couple thousand miles on my 2015 F350 since buying it. Shifts good, runs good, no codes, etc. Still has the oil leaks and water pump leak that I need to fix. I've noticed, though, that the trans temp (gauge and information display) reads incredibly low! Barely breaks 110* and never seen it above 150* towing. This is in ambient temps of 45* avg, 60-70 mph, for approx. 30-45 minutes. Coolant and oil temps are 190* - 205* through this timeframe. Fluid color, smell, and level are all good. The trans has been replace shortly prior to me buying it. Absolutely ZERO history or knowledge of what is in it, who built it, etc. All I know is that the trans case is painted a shiny silver! And the carfax does not show any transmission replacements.
In all my searching, I cannot find anyone with a 6R140 complaining about temps TOO LOW! My 2014 never ran this low.
What could be causing these low of temps? I've considered the trans temp sensor, but not sure where it's even at. And honestly would have thought it'd throw a code for being too low. Any thoughts???
