Update on my rig
IHPowerstroke7.3
Toronto, Ontario
There are only two per cylinder :confused:
Lmao... You funny guy.
There are only 2 rockers per cylinder.. 1 rocker actuates both intake valves, the other both exhaust valves. Its the same setup as the 6.0, the 6.7 however has 4 rocker arms per cylinder, 4 pushrods but only 2 lifters per cylinder.
Where are the rocker arms breaking? Are the balls breaking off the ends or are the clips failing?
HOOV3R
Central PA
That was sarcasm.... They use bridges, just like almost all of the other engines out there.
I know it won't be much stronger and it may have been done or at least said before but what about cryo treating a set of stock rocker?
gotta remember that cryo treating doesnt add strenght. it takes all the grains in the metal and makes them equal so that there is less deformation in each piece and making it less likely to fail do to a flaw in the granular composition...
Erikclaw
Central CA
Cryo way mainly done to help parts not wear out as fast as they normally would
Erikclaw
Central CA
Well #7 is melted, #5 is burnt, one bent valve on 7. Sending heads out to go through and fix the valve. Sending injectors out to see if one hung.
Erikclaw
Central CA
jdgleason
Fort Collins, CO
Wow that would make me sick. I would put a cummins in it honestly.
GTFO of here with that sh1t.
That sucks buddy, did an injector hang open or something?
On edit - ***king lo***kingL on putting a cummins in it.... the most notorious motor for melting pistons lol totally help you with your melted piston issue.
Bustedknuckles
Or you can make the same or close power he is making now daily driven for over 30,000 miles and never have the head off......
jdgleason
Fort Collins, CO
Lol you just described my stock motor.
If the piston had cracked, I'd be less inclined to argue with you, but pistons don't just up and melt because they want to. Almost always an outside effect that melts a piston. Something like injectors, valve issues, nozzle problem, etc. Which is why I find it funny that you suggested a cummins; the commonrails have more injector and piston issues than fords by a huge ratio.
Bustedknuckles
Thats true.... the piston issue is way worse on 6.4's than cummins imo, the amount of 6.4s that have made it over 200,000 miles on the stock engine is VERY low compared to cummins....
jdgleason
Fort Collins, CO
I agree, but the piston flaws seem to attribute to cracking; which is a casting issue from Mahle. Like I said, if this one had cracked, I'd be less inclined to argue...
drunk on diesel
similar to the number of Dodge/Cummins trucks that have made it over 200,000 on the stock transmission, dash board, driver seat, ball joints, ECM, TIPM, HVAC blend door assembly, AC compressor, etc, etc, etc
