VGT Compound Build
1stock13
Am I missing something here? or am I not understanding this correctly, Why would you feed the boost from the precision turbo back into the 61mm oem turbo? Wouldn't that cause all sorts of over spinning problems and issues?
WhiteMamba_Scorpion
Thats a Barder 6670r
Six_Sloww
Southeast MI
It's a traditional compound setup, nothing groundbreaking here.
You feed the valley turbo low pressure, high volume air from the large charger, this increases the efficiency of the small turbo beyond its map.
The wastegate on the exhaust manifold regulates turbine speed on the high pressure turbo
Athens, IL
Just to update
DaCajun
Nice work!!! Looking forward to seeing the results of this mean beiotch!!!
Has the size of the high volume turbo been decided as of yet??? Or are you guys playing around with the three on the tailgate to see which one is better suited for this build???
Again, very NICE work!!! :thumbup:
Black AOD
Ohio
He stuck with his 6670R that was was already in place as the HP turbo. His new LP is a PTE 8891 CEA.
Sent from my VS990 using Tapatalk
Six_Sloww
Southeast MI
This thing is going to be awesome! Morgans doing a great job with fitment from the looks of it. Hopefully you can post some videos when shes all back together!
You should go see it and drop that exhaust off
I do need go buy a go pro.. I always want to post videos but taking them with a cell phone is sketchy
Black AOD
Ohio
I'll bring mine in a couple weeks. You should probably just go ahead and buy a spare set of tires if you catch my drift..... :0
