Six_Sloww
Boner.
Ugggghhhhhh
Cooddddyyyyy. I want a ridddee
Sent from my VS990 using Tapatalk
Boner.
Ugggghhhhhh
It's a traditional compound setup, nothing groundbreaking here.
You feed the valley turbo low pressure, high volume air from the large charger, this increases the efficiency of the small turbo beyond its map.
The wastegate on the exhaust manifold regulates turbine speed on the high pressure turbo
I was assuming you would use the smaller turbo to spool the larger turbo sooner, I know you guys know what you're doing, and I'm in no way questioning the work, I've never really dealt with compounding systems at all. I'm just trying to understand, how this would be more efficient.
I was just thinking about a similar set up to this last week. Glad you are trying it. Should work well.
If all goes well it should be about the fastest spooling 1000hp capable turbo setup.. Fingers crossed!
I'm curious just how fast this setup will spool...
