Mwilbur516
- Joined
- May 22, 2011
- Messages
- 4,700
- Reaction score
- 2
Probably the most impressive vgt truck out there. Awesome Mike!
I agree.
Sent from my BNTV400 using Tapatalk
I had elites original VGT-SS for a while and it did 585hp on fuel and 823hp on spray. Swapped to a Barder Stage 3 and truck did 615hp on fuel and 865hp on spray. No tune change.
The SSX has a 64.7mm compressor wheel and the stage 3 has a 68mm so that makes sense.
Your correct, I did say VGT-SS though, not SSX. This turbo was built with a gt40 compressor housing and not out of powermax. Fwiw the stage 3 spools faster than the VGT-SS, 64.7mm. Spools as fast if not faster than a stock turbo tbh.
What makes it spool faster? Is the A/R different on the harder unit? Number of blades? Billet?
That my friend are questions for the turbo builders, I have no idea what the specs are for each turbo besides comp wheel size. I can only give you the info on the way MY truck has reacted to each turbo.
Thanks for correcting James. I got those specs off of what someone had posted on the org. My bad man!
