Warren 190/75 issues
Powerstroked162
On Da Juice
Wa. State
Man, I would honestly stop and get them flowed. I've been hearing of some issues with those particular injectors not being balanced when they leave the builder. Maybe some of the other guys can chime in
Cory S
orlando fl
thats what i am thinking. Tim @ PIS is pretty close so i might get ahold of him
Whose tuning?
Sent from my Milestone X2 using Tapatalk 2
Erics
Call me when you put ae on it, sounds like a spool valve.
spool valve? yea i will hit you up
chappy
Marshall Mi
Yeh my buddy is running warrens 190/75's. 3 went bad on the first set after a couple months. 2 more went bad a month later and 1 of the 2 that showed up were bad right out of the box. The second went bad 2 days later before the replacement even got here. Hopefully you don't have the same luck
MorganY
college station, tx
Been through this before ^
speedracer1000
everett, pa
i recently jus installed warrens 190/75s and have put 500 miles on em so far. seem to be jus fine im happy with em but ive been seeing alot of guys havin trouble with em lately i hope my luck dont turn around... i know jesse would make it right but still
05wh250
hendersonville, nc
Hey man what were the symptoms? I just put 190/100's in mine and don't know if its the rough idle from the way there modified or i got a couple bad injectors? I've pulled codes for contribution on # 4 and it stopped that and started pullin em for#8.
Derek@Vision Diesel
Canby, OR
Does anybody know if Warren benches the injectors before they leave to the customers?
I was under the impression they didn't have a flow bench but were in the process of getting one. Not sure if they have someone close by that possibly flows stuff or what, but I believe I heard there was not a bench in their personal shop.
Have had great luck with Warrens product here, installed plenty of 155/stock nozzle. Damn near every 6.0 through the shop gets a set.
BlueWaffle
Grapevine, TX
I thought they were very few flow benches around the country. RCD, Full force, I'm sure hypermax an d industrial injection have them. I'm pretty sure when I asked if they flow their injectors they said they do not...
Powerstroked162
On Da Juice
Wa. State
Which would explain a majority of the issues people are having, on top of the core issues Kyle mentioned being thrown into the mix. Hopefully Warren takes care of you guys
Jeremyleggett07
Katy, Tx.
I was under the impression that one of the reasons why warrens wee so much more cheaper was they didnt. Flow test and were rebuilt from cores, not remans!
