Warren 190/75 issues
Craig@MFI
You don't belong building 6.0 injectors if you don't have a flow bench or access to one period!
Breaking Habits
Mapleton, Illinois
I was under the impression they didn't have a flow bench but were in the process of getting one. Not sure if they have someone close by that possibly flows stuff or what, but I believe I heard there was not a bench in their personal shop.
Have had great luck with Warrens product here, installed plenty of 155/stock nozzle. Damn near every 6.0 through the shop gets a set.
We've offered to flow every set Jess builds for him at an extremely low rate. Should help him narrow down warranty claims.
Sent from somewhere away from my desk using magic.
java
Texas
I had an issue with one of my injectors from warren with about 3k miles on them, replaced it and now I have a miss when the truck is cold.
Jwarren
Building from good cores we never have a problem. Spool valves can be very tricky. Over all we dont have to many issues. Truck in the video have a good FICM?
Call our shop mon-fro 9-5 we take care of our customers
Jwarren
I have just as much access to a flow bench as you do. Ive run injectors on the same bench you guys use. Its not in your shop.
Extended Power
Just so everyone knows...
I LOVE MY WARREN DIESEL INJECTORS!!!!! :rockon:
Jesse is one hell of a guy.
Great customer support...he even calls you back, of all things...:D
I would suggest his injectors to anyone looking for a set.
Jwarren
We do our best.
There is a shop out west farther we have sold 50+ sets to and only ever had 1-2 injectors fail and they were from defective o-rings.
Got to keep in mind when building 6.0l injectors from used cores there will always be a failure rate. We try to keep it low and keep quick convenient service to all customers.
All problems we have seen are spool valve related.
Houston, TX
We do our best.
That's what i was getting to, I haven't had any issues with new units. Had two used cores that have been warrantied.
Powerstroked162
On Da Juice
Wa. State
Stand up move, Jared. Kudos
We do our best.
I dunno about all that.... I've heard some stories of bigger injectors not being balanced or flowed before leaving your hands and being off substantially. Puts the customer in a pretty bad spot, IMO whether you make it right or not. As far as cores go, does the customer automatically get their injectors built on cores or do they get to decide? I know the 7.3 injector guys used to leave the customer the choice of having injectors built off either new/reman alliants or set of cores to save money. If thats the case, then its really hard to put fault on warren for that, IMO. Either way, I hope you guys get it worked out
Cory S
orlando fl
just got off the phone with Jess @warren Diesel
here is the low down i am sending him the injectors out of our truck which were bought brand new from ford about 20000 miles ago. he is going to build those to 205/100's at no extra charge and flow them. i am keeping the 190/75s until i recieve the 205's in from jesse so the truck is not sitting there with out injectors.
Jesse i really appreciate the call A+ customer service.
04stroker
Sarasota-Bradenton, Florida
Jesse does give the option to have built from cores or new Alliant injectors for the additional cost for them of course.
Powerstroked162
On Da Juice
Wa. State
Pretty cool
05wh250
hendersonville, nc
If you don't mind me askin why are you stepping up to 205's?
Cory S
orlando fl
well i have a t4 set up coming from from MPD with a non vgt 64/xx/83 billett going to use some Laughing gas for a lil while but going to build a set of compounds for the truck.
