_DieselPower_
Okay so its that time of year and roads are flooded and their is water everywhere! Well I was going through some water one night countless puddles on my way home. Well the next day I was going to school and she wouldnt shift into 4th. It was all of a sudden just gone?? I couldnt get my trans higher than 3rd gear. It normally runs at 140 degrees and it was getting up towards 160 so their is a problem. Is it shot or do you think a trans flush would work? If a trans flush would work does someone wanna walk me through it? I know drain the oil take off the pan. Change the filter and gasket and reinstall. Anything else I should check?? My trans fluid is full but it does smell a lil burnt but not bad.
Transmissions are not my highest level of expertise by any means so if ya could give me a hand with it, it would be appreciated.
