- Joined
- May 22, 2011
- Messages
- 15,240
- Reaction score
- 1
I'd do the ported intake mani before cam, valvesprings, or pushrods
Yep.
I would do option 2 honestly, the 60's and II pump on mine hold full rp. Just a warning the II pump on the race tune takes a bit getting used to driving wise, its a bit touchy.as everyone knows i have mpds 72mm kit along with a suncoast converter. but still have stock fueling and tranny, since i got good news from my tax guy i plan on addressing those issues, but id like a few opinions.. first of all rudys will be doing the tranny build just havnt decided on what all else ill b able to do.
arps,pushrods, rcd cam and valve springs, 60s or 30% overs, ported rails and intake manifold, and airdog with fuel bowl delete
or
arps, 110s or 60% overs,ported rails, dragonfire pump,and maybe pushrods and valve springs
will eventually like to have it all but ive only got so much to spend and this is my dd and only thing i have to drive right now.
I would do the springs and pushrods while they are easy to get to, then once you have money pull the 72 off and do the intake. I'm sure with a single turbo set up, fuel bowl deleted, etc. It would be quite a bit easier to do.
Its too jumpy arpund 50-60 it tends to want to buck. Do you have the new ford flash
Sent from my Droid Charge
I'm no mechanic but i've heard the intake manifold is hard to do cab on due to all the hoses and wires that have to be moved out of the way to get it out.
Still probably easier than springs and pushrods cab on, haha.
