WHAT EXACTLY DID I SCREW UP
How the ***k does a bts just bust apart going over an intersection? Did you jump the mothereffer and not let off the throttle? This doesnt make one bit of sense....:lookaround:
It happens. If it was spinning and stopped abruptly... IE; catching air under the back tires.
Isnt that what I said?
Ive done that with a stock trans but never busted anything. Would think the bts wouldnt grenade that easily.
550+/-hp vs. 300 is a big difference... **** happens, nothing is indestructable...
At 50 miles an hour he is making 550? I dont see power being much different at that point in the pedal. Unless he was at wot when it happened. I would think the smaller tires he's running would have helped...
Who's got 300 hp?:D
JAP
Diamondhead,MS
If he gunned it to beat a red light then yes...
I don't know how much power you're running. Regardless, **** breaks. He shocked it bad enough to BREAK HIS DRIVESHAFT.....
blackbetty13
Oh drive shaft was good I thought it had separated because the rubber boot by carrier bearing was moved.
No he didnt! :)
I agree only with the part where you said "shti breaks"
